How can I tell what model my camera is?
If you have the camera installed already check in the app settings/ support / the camera for the model details at bottom of page.
Else open the battery compartment of the camera remove battery and look for a label with VMC....
If you don’t have a removable battery, you will likely have the arlo essential camera unless you have a wired camera like the arlo Q.
The older arlo wire-free Cameras use multiple CR123 lithium Batteries.
https://kb.arlo.com/290/What-kind-of-batteries-does-my-Arlo-camera-use
Thank you! The model number is on a label inside the battery compartment (Pro 2)
1  -
1  -
1  -
