How can I delete content from an Arlo library?
  • 2 Replies
  • 3437 Views
jscottadams
My camera's have not recorded anything for several days.  Cameras active, good battery and events in the environment are present.
There's a disconnect between the title and message - they're totally different things.
As for your message, have to tested the system to see if there's anything to record?  Have you tried to trigger the system yourself by walking through the field of view?  Have you increased sensitivity?
jscottadams,
It may also be helpful to check the rules set for the active mode. If the rule that tells the camera to record on motion is not active you will not see the green "running man" on the cameras screen which indicates the camera is set to record when it detects motion. Please let us know if you were able to resolve this issue!
