How To Change The Arlo Record Time Length
  • 1 Reply
  • 1917 Views
animalluva
My recording length is only up to 10 seconds each clip even when there is clearly more movement happening. How do I change this ?
ShayneS
animalluva
To change the desired time frame you will need to go to Mode Tab > Base Station >  Desired Mode > Rules > ( Under: Then Do The Following ) > Record Video ( Pencil Icone/Edit) > Record For A Fixed Length Of Time > Adjust > Save > Save.
