My recording length is only up to 10 seconds each clip even when there is clearly more movement happening. How do I change this ?
animalluva
To change the desired time frame you will need to go to Mode Tab > Base Station > Desired Mode > Rules > ( Under: Then Do The Following ) > Record Video ( Pencil Icone/Edit) > Record For A Fixed Length Of Time > Adjust > Save > Save.
