  • 6971 Views
2112
Hi
If I am getting a low signal strength on the Wifi icon on my individual Arlo cameras, do I need to reposition the Arlo Base Station or the Wifi Router?
It is not clear to me what signal the cameras utilize.
Also not clear to me if a Wifi extender would provide me any benefit.
The cameras only connect to the base - your home WiFi has no bearing. Repositioning the base may be useful, perhaps only a few inches/feet, so the signal is adequate for all cameras.  A WiFi or powerline extender may be useful so you can plug the base into that device for that centralized location to help all cameras get a good signal.
2112
Thanks for the tips.
Is the camera's connection performance impacted whether there is 3 beam signal strength vs 1 beam signal strength?
Potentially, yes. I've had 1 bar and not had issues but that's a pretty gross measure (only a few bars to measure the whole range of strength). A weak signal could produce weird issues as well as battery drain.
