Help setting up base to router
I received an older camera and am trying to connect through a Nighthawk router. It will not connect. Obviously, it is out of warranty, but the base station and cameras do work. I have a Gearhead contract, but am unable to speak with a live agent for Arlo. The virtual assistant is useless. How to speak with a live agent?
First only contact to Arlo is via here... https://www.arlo.com/en-us/support/contact
( tho since they are old and you don't have a service plan or trial, the live person is prob out )
Second, the camera running thru the Nighthawk router directly is no longer an option ( tho it was about two yrs ago the sw never really panned out to work 100% ) TMK .
Third, if the base unit is good... ( properly removed from the old owners account ) then set up an account first. Using the web may be easier at my.arlo.com
Once you set up an account, use the add device / follow directions and the base via ethernet cable to the router should get it to work after the base , add the camera also
Thank you for responding. The base unit is good. I did set up an account and added the device. It tried to do a firmware update but was unable to access internet. The power light shows amber. However, it does try to boot up (turns green), frequently, but can't access internet. I figure the router is the problem. However I have been in touch with Gearhead and they say no. I know all equipment is good bc I received from my daughter. It was working with them. Yes, they did remove from their account.
Have you tried a different ethernet cable? Also, you might want to try a different LAN port on the router.
The power LED being amber is a problem. Could be the base or the power supply. Fix that first.
