Having trouble logging in to the App with error message
Keep getting the message "We're sorry, Arlo is currently unavailable. Please try again later." I have the cameras for 3 days and for the past 2 days I keep getting the same message off and on. Sometimes it let's me on but most the times I am getting the message. Will it still record even tho it's not letting me sign on? Does this happen often?
Same issue! It's freakin annoying! I've had the system for a couple years and no, it does not happen too often, but yes, it does happen from time to time, which is really unacceptable considering we rely on alerts for security. Your cameras SHOULD still record (you can log into the desktop version at arlo.netgear.com and check your library), but you will not be alerted while this is error is going on.. it's an app issue. No app = no alerts. Maybe they're updating the app and they'll fix all 697 problems with it! Hah, yeah right.
Hey @Cduke1986 and @dhiller0217,
Do you have a screenshot that shows this message when trying to log in? What phone are you using and what phone version is it running on? You can also try reinstalling the app to see if that resolves the issue.
Thank you!
Thanks for the screenshot. Have you tried to reinstall the app and see if the issue persists? Does this error occur when you're on WiFi and/or cellular data?
