  • 12 Replies
  • 8481 Views
  • 5 In Conversation
ArveH
I have a grey screen on one of my Arlo cam. Im able to set it in live modus via the app, but its still grey.
Via the web-browser, Im not able to set it in live modus, then I get the message that it times out...
I have another cam, and thats working fine.
Im in Norway, and the cam is in Spain...
Any solution that doesnt require me to fly down to Spain?
12 REPLIES 12
You can try remotely rebooting the base which may or may not work. If not, it may be a hardware problem.
ArveH
Hi and thank you - but sorry, this did not help...
gt999
Any updates here? im experiencing the same issue. Thanks!
ShayneS
@gt999
What firmware version is your base station & camera running? Also, what OS is your phone running & what is the version of the Arlo Mobile App you are using?
ArveH
Sorry, no solution yet...
ShayneS
@ArveH
Have you tried to remove the camera from Settings > My Devices And re-add it?
ArveH
Hi
I think "everyting" is updated, but in a few days I will be in Spain, and I will be able to check it more 🙂
ArveH
Hi
No, we live in Norway and camera is in Spain. But in a few days I will be in Spain, and I will be able to check it more 🙂
misspixels
I have the same issue with one camera. Turns faded gray on live screen today. Any solutions?
thanks
Post a screenshot so we can see. Is it possible that the light level is low enough for the camera to switch to night mode?
misspixels
There you go! 🙂
Left is when the screen go faded gray and right is the daylight and juste befor it turn gray. 🙂
Just answered in your other thread.
