So geo fencing had been working for well over a year and now it’s not, anyone else ??
I knew it was only a matter of time until Arlo broke something again, useless
Best answers
Thank you all for the continued feedback. I provided all of your additional information to the team, and I will report back as soon as possible.
We have identified the issue where Geofencing (Arrive/Leave) automations may stop triggering automatically. A fix has been developed, tested, and confirmed working. It is currently awaiting Apple review and will be available soon. I will continue to provide updates here. Thank you for your patience
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
@JoeyRG wrote:I spent over 2 HRS On teh phone with Tech support 2 different agents and the only thing they had me do was change the Geofence radius from Med to Small.
Are you using an iPhone? Several folks have posted issues with iOS 26.5 and the current app.
@Ttonim wrote:
I also couldn’t find any proper way to create a real support ticket. You either end up with the AI chat, which is not particularly helpful in cases like this, or you are told to call support — which is not an option for me either.
So this is a serious question: How can customers actually create a proper support ticket with Arlo or escalate an issue directly to technical support — especially as a paying Secure Plus customer?
Those are the two ways. Not sure why calling support is not an option for you.
Though Arlo has to know about this issue - I'm tagging the mods - @BrookeN , @ShayneS , @JamesC - in hopes they can provide an update.
Yes I am IOS 26.5
I am having the same issue, I should have Googled IOS 26.5 Issues before calling tech support as I wasted over 2 HRS for them to tell me to change Geofence Radius.
I am having the same issue, I should have Googled IOS 26.5 Issues before calling tech support as I wasted over 2 HRS for them to tell me to change Geofence Radius. Their Tech support is an absolute Joke.
Spent an hour with customer service trying to fix the geofence issue but still the same…
made me erase and install all the modes and automatic settings but still not able to switch modes automatically. Really bad!!
Thank you for reporting. I have notified the team regarding this and I will be sure to update you all here as soon as I have more to provide.
Is this with iOS or Android?
Am having same problem—everything was working fine until last week. Suddenly, Geofencing does not work. Am a subscriber w 10 cameras. Arlo Secure app geofencing map shows when I leave and depart but does NOT actually activate the Geofencing automations. All permission settings are correct. No duplicate iOS Devices. Have uninstalled and reinstalled app at least 3 times. Very frustrated.
Same issue for me as well.
Same…
IOS 26.5
Arlo 6.28.0 (25993)
Thank You
I’m trying to set custom routine with geofence… may it works? Home know but will see when I leave if it works automatically this way…
So Support was supposed to call me back at 8 AM, He ends up calling me around 2 PM, Asks me to make sure always allow is set on my Phone for the app to track. Then says that is all he has and will call me back tomorrow with something else to try lol.
I told him that he should know that this appears to be a issue with Iphone and App update.
@Ttonim wrote:
I configured it this way so that if someone is manually or accidentally switched to “present/home”, leaving the zone afterwards would still correctly switch the status back to “away/not present”.
That was the reason for the separate automations
Still confused on the rationale. If someone was at home, then the system wouldn't be in Arm Away in the first place (since not everyone had left). And if they had manually switched the system to Arm Home or Standby, the single automation would still have triggered when the last person at home left.
The effect of separate automations is to switch to Arm Away whenever anyone leaves. Which is ok I guess if everyone tends to leave together.
@Ttonim wrote:
and it worked reliably before the recent update.
There's definitely something broken - I'm seeing the same behavior on my own iPhone (and provided an app log to Arlo).
So the app has updated to 6.29.0 but when i left home this morning the automations geofencing still did not work. I clicked "test automation" and it worked.
Has anyone updated to 6.29.0 and still not working for you?
@ShayneS this major / priority 1 issue is already existing for multiple days. It severely impacts many users. Apparently it is hard to fix. Did you consider to rollback the last update so that all least we have working geofencing solution again.
Updated the app to 6.29.0 on all devices and still the same. Geofencing not working! 😞
Upgraded from 6.28.0 to 6.29.0 this morning. Geofencing is still broken. The last working release was 6.27.0.
I hope we will finally see a fix in 6.30.0.
I have to wonder what is going on at Arlo, that they make a new app revision every few days. It is hard to believe that they are testing these or waiting to see the outcome of the release.
It also makes troubleshooting extremely difficult as it’s very unlikely that the app version used at the time a ticket is opened will be the same version in use when the support agent replies. Frankly I have had tickets where every single reply related to a new app version.
Edit - To put a number on this, this is the 25th new version released in 6 months, a pace of one release per week.
Same. Upgraded with no change. Geofencing still does not work!
Regardless if you arm or disarm the location, Geofencing should trigger a response when you enter or exit the zone.
Same here upgraded to the latest Arlo app that appeared today on the ios app store, still geofencing is broken
Just upgraded to 6.29.1… seems to be fixed! Finally!!
