Geofencing Phone Unavailable
My iPhone had some problem and the Apple Store made me restore as a new phone so everything was gone.
My GF used to work fairly well but now upon trying to set it up again, my iPhone is enabled in GF but it's listed as "unavailable". Location services is on and I have everything enabled in Settings:Arlo. Location there is 'always'.
I've read some posts that said to disable the phone, save then re-enable but that doen't change anything.
Thanks,
bo
onobo,
Consider reinstalling the Arlo mobile app. Be sure Arlo has the appropriate permission enabled (location) and try again. Do you still see the same behavior?
I have the same problem with the app not recognizing my phone for geofencing. It's listed as "unavailable." It has all the right permissions enabled. I tried deleting and reinstallling the app. This doesn't work. The feature clearly has a bug. Please fix. I need to use this feature
jalfano,
Consider disabling your devices under the enabled list in your Geofencing settings, save, and then enable the devices again.
Do you still experience the same behavior?
I am having this same exact problem with my wife's new phone. The new phone shows "unavailable". I have reinstalled the app, enabled/disabled location settings, deleted her as a user and resubmitted her as an authorized user, and nothing is working. What is the fix for this. We are on the same wifi network.
SFEERO,
Try disabling all devices within your enabled devices list in geofencing settings, save, and then enable all devices again. Do you still see the same behavior?
Same behavior. No change. Is there a customer service agent that I can speak to on the phone to get this issue resolved?
Use the Contact Support link at the bottom here.
I don't know if this will help you but I believe I know what is happening. Assume Home == Away and Away == Home and set your Arlo system that way. I believe that when updating the iphone application Arlo may have inverted the Home and Away titles, it is working for me after I set the Home setting as Away and the Away seting as home. In summary the titles Home and Away are wrong, in my case (I also have and iphone 😎 the geofencing is working but the lables are wrong.
An interesting twist. Reversing the labels works for my iPhone 6S, but not on my wife's iPhone 6 plus. Putting the labels back to mean what they say works properly on her phone, not mine. Also, the labels were fine on my iPhone back in July and on until just a week or two ago. This is a very recent problem for me, even though my phone is the same, and the only difference is an upgrade to iOS 11.1.2.
I had to rename each of the iPhones in iPhone settings. That seemed to be the trick.
Motionist,
Are there any special characters in the device name for your wife's phone? (JamesC's Iphone) If so, remove the special characters and see if you still experience the same behavior.
You might also try refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Log in to your Arlo Account (the primary) and navigate to Mode > select your Arlo system > edit Geofencing > click "Enabled devices". Toggle all of the listed devices off and save. After you have finished saving, navigate back to "Enabled devices" and toggle all desired devices back on and save.
Same issue here, occured recently - I assume after the latest app update. We have two iPhones tied to geofencing. They are constantly not refreshing their positions, being either ”unavailable” or wrongly out- or inside the geofencing zone. One has to manually disable/reenable the unit in the geofencing settings before it refreshes its position. Once refreshed, the app behaves correctly and disarms/arms cameras according to our settings.
It’s like there’s a bug in the app, or something is not aligned with the latest IOS update, that hinders the app to poll the unit’s gps-position. The Arlo app has the maximum credentials to access position data in each phone, so no issue there. It also worked perfectly until recently.
My five cents on this subject is that you Netgear guys have a bug to fix!
my goodness, to do somehting so simple, netgear makes it so complicated. how on gods green earth do i rename the phone?
Kept getting “Unavailable” on my Georeference setting. The georeference mode would not recognize my IPhone 6 or my wife’s IPhone. I tried everything recommended above and what worked was when I renamed my and my wife’s phone. I changed, “H’s Phone” to “H” and did the same with my wife’s phone and it now works.
To to change the name of your IPhone:
1. Open “Settings”.
2. Open “General”.
3. Open “About”.
4. Open “Name”.
5. Erase whatever is there and rename your phone to anything using just letters. Do not use any punctuation like an apostrophe or hyphen.
To the Arlo Techs......Please fix this.
