I have added a fifth camera recently and my freinds can't see it. I resend the invitation checking the fifth camera. What i'm I doing wrong?
r273,
It sounds like the friends invitation that you sent expired. Consider deleting that friend entirely and resending the invitation with all 5 cameras shared. Then be sure your friend accepts the invitation by clicking the provided link within the e-mail and signing in to their existing account. You may find this part easier on a PC, on a smart phone the link will prompt you to download the Arlo app. You can find this entire process in the following article:
How do I add friends to my Arlo account?
I hope this helps!
Go to the Friends selection in Settings and enable the various cameras for that person.
Did you not read my question? I resent all cameras plus the 5th one.
Sorry for my short anwser to my last post but it is quite flustrating friends can see my 5th camera after sending many times as the instructions read.
Now my friends can see ANY cameras. They can down load the app but when they open it to the cameras it is a blank page. Top left of that page shows 4 little green boxes. Also on my settings page there is a red triangle with a explanation point in the center located on the line labeled "Friends".
Do I need to delete my account and reload?
r273,
I hope this helps!
r273,
What is the status of the invitation now, is it showing accepted or pending?
Pending
r273,
I have reached out to you in a private message about this issue.
Thank you JameC for your phone conversation! JamesC was able to talk me though a way to enable all of my cameras!
Thank you JamesC, from a happy costomer!
Thank u
Michelle
Hi Michelledee, in my case I was trying to sync my cameras to my wife's I Pad or cell phone but it would not work after I added a 5th camera. Then none of them worked. JamesC Netgear Moderator helped me to do it a different way. You need to sync cameras from PC to PC. This worked again for a second friend.
Hope this helps.
R273
Hi r272,
What do you mean by syncing the camera from PC to PC? I had the same issue where a previous arlo hub was returned and i have synced the cameras with the new hub. I can see the cameras but my friend, who I have added, cannot.
Did the friend respond to the email that should have been sent to him? There's the need for response to authenticate the friend's account.
There was no problem with the previous hub. With this new one, the setup was exactly the same, the friend did click on the link that was sent. The link opened the Arlo app (with iOS). He logged onto the same email account used for the previous hub that we have owned. The camera screen do not show any cameras and the friend status is still pending..
For future reference what did you do to resolve your problem on the 5th camera, Noneofurbusines?
