  • 5 Replies
  • 5372 Views
AlexDan101
I just moved house and my Arlo hasn’t been in use in a while. I connected up the base station via the app and it found the base station with no problems. However I just keep getting the firmware could not be updated message and can’t get past that
5 REPLIES 5
You may have to do a factory reset of the base to get past this and update FW
dtognazzolo
I didn’t use my arlo cameras and base for a while. Now I connected just the base for then to sync the cameras but the base (vmb3000) cannot be updated. I tried several times with no success. I’m using the new app (app problem message attached).
I also reset the base with the back button but same message pops up.
ShayneS
Hi @dtognazzolo
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech support
dtognazzolo
Hi, thanks! But I’m in Uruguay and there is no Arlo support team locally. Which support center should I contact in this case?
ShayneS
Hi @dtognazzolo
If you click the flag in the top right corner of the support page in the link I provided, you can choose the region of your choice.
