Certain Camera areas not recording
Certain cameras in certain areas does not record anymore. I can view and record but when motion is detected, it no longer records. I have tried swapping cameras, re-syncing cameras to base station, and restart base station. If I resync the cam. It will record per motion for the first few times. Then after a hour or so, it stops recording via motion. Any ideas?
Hi @Axix23
Same issue here. Please fix
Same here with only one of my cameras today, it’s triggered twice but missed several that other cameras have picked up and that one should have and normally would have.
Can you try & remove the camera(s) from Settings > My Devices > Re Add & test again.
