  • 4 Replies
  • 2397 Views
Axix23
Certain cameras in certain areas does not record anymore. I can view and record but when motion is detected, it no longer records. I have tried swapping cameras, re-syncing cameras to base station, and restart base station. If I resync the cam. It will record per motion for the first few times. Then after a hour or so, it stops recording via motion. Any ideas?
ShayneS
Hi @Axix23
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
daveybb
Same issue here. Please fix
Adksi11892
Same here with only one of my cameras today, it’s triggered twice but missed several that other cameras have picked up and that one should have and normally would have.
ShayneS
Can you try & remove the camera(s) from Settings > My Devices > Re Add & test again.
