False alert when logging in
When the system is enabled (alarm set) I often (say weekly) receive a false alert when logging in to either check status or to disable alarm. Although the alert tends to be from one camera it has occurred on the other cameras.
kde,
Consider a base station reboot (using the on-off button). Allow the base station to come back online and test again. Do you still see the same behavior?
It was reset a few months ago and the alerts continued.
But I'll give it a try again.
It may take a few weeks before concluding anything.
Thanks for suggestion.
