Tried holding the reset and synk buttons for more than 40secs and no amber color... still green
is any other method to get a factory state? BTW I'm trying this because the whole system went off and disapeared from my dashboard (I have no devices on and impossible to conect)
ok, after multiple intents, (I did unplugged for a while and follow the rest button (only) procedure) I finally got base reset and cameras connected again.
Thanks for your help.
Just hold in the reset button for 10 seconds till front LED flash
both buttons held is the old way
I did try that (initailly). holding, holding... my hand was numb already (over 45 secs), also I left it unplug for more than a min and reconnect everything again with no sucess.
I am having the same problem! Factory reset not working, my base station does not connect to my email account.
I'm definitely hitting the buttom, heard and felt the click when I pressed it and held it.
My initial question was: is any dfferent way to factory reset the base?
OK, got it... I was pressing the sync and reset at the same time. A firmer push of the reset button only has me reset and I have one of my cameras up. The other 2 cameras haven't sync-ed to the base yet after multiple attempts. Any suggestions?
Leftyoak27,
What is the LED behavior of the base station and the cameras when attempting to sync?
Be sure you are not holding down the sync button too long (press and release) to allow the base station to enter camera sync mode.
