Extending Arlo Base station
Hi ,
I have 8 Arlo cameras around my house, with a Google mesh system so WiFi is good... One of my Arlo cameras at the end of the garden has weak WiFi signal due to the distance from the hub, can I add another Hub to strengthen the signal nearer my camera at the end of the garden ?
Alan
Alan
Yes... adding multple bases is the ONLY true way to expand coverage area.
There is no limit on the number of bases on any level account. ( nor location )
So add a second base and then sync the closest cameras to it.
A side note; Two bases will need to be armed separately, but it also can have advantages.... exp; I split my cameras to front/ back... this allows two schedules to run ( one on each base ) and allows custom modes to fit the front / rear areas
