Email notifications have been turned off and saved according to the instructions, but notifications are still being received. Why?
Update: I have even tried turning the motion off using the Schedule feature. It is still capturing motion and sending emails.
rmurph wrote:Update: I have even tried turning the motion off using the Schedule feature. It is still capturing motion and sending emails.
Check if the " running man " is green when this happens after turning off the schedule...
If he's still green( after turning off ) either the schedule or mode is set up incorrectly
Have you checked each rule to verify email notifications have been disabled? Toggle the check marks if necessary and then be sure to use the Save button both on the email screen as well as the rule - do it twice.
