Double blinking amber light
Trying to sync one of my four cameras and it continues to double blink the ambler LED... what does it mean?
Means ng ....on sync.
open and close battery door ( chk batteries) , then try again.
remember it's a quick push on base sync button to hold.
cdrbernard,
This could also mean low/depleted batteries if the amber LED is blinking slowly (even when not attempting to sync).
If TomMac's suggestion above does not work, consider installing a fresh set of batteries and try again.
