  • 5 Replies
  • 817 Views
arejames60
cant login doest recongize my device
5 REPLIES 5
BrookeN
Can you change it to send the 2FA to your email address instead of the iPhone?
arejames60
Yes i tried sending to my email but got sane results
@arejames60 wrote:
Yes i tried sending to my email but got same results
Are you saying that
  • you never got the code?
  • or that the code wasn't accepted?
arejames60
i never got the code with any device selection all timed outside
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
