Does Arlo products support outdoor AP?
Hello, I would like to know that if the Arlo wire-free camara products support any ourdoor access point. I want to use these movable wire free camera for specific task within the factory. (which the range is around 700m long). So, I have to use outdoor APs (multiple spots) along with fiber optic. Does the product support outdoor AP like https://www.ubnt.com/unifi/unifi-ap-outdoor/. If anybody has some solutions or advice, please do not hesitate to help me out.
Thank you
Jinn
Arlo wirefree only connect to the base station, as do Arlo Pro.
You might find Arlo Q cameras suit your needs, as long as you have a power point where the camera needs to go
