Disconnected Camera
One camera has lot connection, it will not sync back up.
This is the message that i have.
Your device is not connected. Make sure it's connected to your router and has a working Internet connection.
mike11613,
What is the LED behavior on this camera when opening and closing the battery compartment door?
You might consider replacing the batteries in the affected camera with a fresh set and try again.
