camera won't stay connected
Batteries are fine, but my camera stops working after a while. Screen report notes that 1 of the 5 cameras is not connected. I sync it again and it still quits working after a few hours.
it may be location..swap it with one of the working cameras to see if the problem follows the camera.
Daisyrenee,
Did the above suggestion by TomMac help? Were you able to isolate the issue to the location? Please let us know.
I am having the same problem with NEW system. I have 8 Camera's and 7 work perfectly, but 1 of them will sync up fine and show video then it will go off line and not work again till I remove from system and re-sync it then it does same thing all over again.
also my Base Station says it needs new update but it will not update firmware when I try it. system is only 3 days old...
please help
Ron
teampurpleracn,
You could try swapping the location of the affected camera with a camera that is behaving normally. This will isolate if the issue is with the location of that camera and it is dropping offline due to poor signal strength or interference.
The Arlo base station will update automatically on it's own overnight. Current firmware is 1.7.5_6178. Is your base on this firmware? Does it still tell you that there is an update available?
Its definatly not a enviromental deal. it doesn't work anywhere I put it, once I sync it and picture shows up. then once it times out it will go off line and never come back till I remove it and sync it again. its not even installed beacuse it wont stay online long enough to put it somewhere and adjust it. like I said 7 of the 8 camera's work perfect
Base station- yes it shows it needs an update but it is on the current firmware.
teampurpleracn,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
