Disarmed system still recording
  • 4 Replies
  • 2593 Views
Heathab
System is disarmed but still recording. We have to shut the base off to stop it.
Heathab,
If you restart the base station, do you still experience the same behavior?
Are you using any custom modes?
Heathab
Base reset does not help. Seems that just the outside cameras are still recording. But system is completely disarmed.
Consider removing and re-adding the problematic cameras and then test to see if they behave correctly according to the active mode.
Heathab
Tried removing all cameras and problem persists. Completely disarmed and still records.
