  • 34842 Views
drgallo
With the other video cameras in my house (not Arlo), I was able to use an application like SecuritySpy for the Mac, enter the IP Address of the camera, then enter the Port Number, username and password, and I could see the video stream. Can I do this with Arlo? I can find the IP address of the (VMB3010) Arlo Router, but that is as far as I get.
No, you can't...  remember the cameras don't stream to you main router but only to the Arlo base.
The Arlo base will have an IP in your home router.
IF you could get into the base ( which is locked ) then maybe you might get a bit of acces to the camera, but the stream that is processed from arlo base to the cloud is encrypted ( thru your router )
RafRaf
What about Arlo q? Direct view of Arlo q Camera using IP address ?
Nope. They're not IP cameras.
