Devices (cameras) are Offline
  • 6 Replies
  • 7699 Views
dpoon
I am having the same issue that many have had previously but none of the solutions in the other threads seem to resolve this issue.  About a month or so ago (June 2018) I could not connect to any of my four cameras.  When I try to access the live feed, it attempts to update but then I receive the "The device failed to connect.  Please try again." message.  When I try again, I receive the "This Arlo device is offline" message.
After opening and closing the camera battery door, changing batteries, power cycling the base station, and power cycling my router, without success, I removed both the base station and cameras from the desktop website, factory reset the base station, and then using the Arlo app added the base station and each camera following the usual instructions.
I have deleted the current IOS Arlo app and installed the latest version, on both my iphone and iPad.
After performing these steps a few times on both mobile devices, I am still unable to connect with any of my cameras.  The base station shows all three green lights on (power, internet connection, and synch).
I believe that I've covered all the steps, without success.
I would love to add to my existing system with the Arlo Pro 2 and the Arlo Security Light, however I would like to resolve this current issue of course.
Thanks in advance for any help that you can provide me!
dpoon
I thought it was unusual and coincidental that all four of my cameras would go offline at the same time, with the only common factor being the base station.  So I replaced the base station with a new one, and all four cameras came back online.
6 REPLIES 6
steve_t
Master Master
What are your speedtest numbers for up/down/ping for both your base station and your device?
Also, have you tried a browser?
dpoon
Hello, I'm not sure how to find that information for the Arlo base station and devices, but the ping/up/down for my Iphone 7 and PC are as follows:
Iphone 7
Ping:  12ms
Up:  14 mbps
Down:  30.9 mbps
PC Ethernet Connected
Ping:  10ms
Up:  15.3 mbps
Down:  179.2
PC Wifi Connected
Ping:  11ms
Up:  15.1 mbps
Down:  38.7 mbps
Thanks in advance
dpoon
Hello, yes I tried the Arlo site on Firefox and Edge and experienced the same issues.
steve_t
Master Master
Hmmm those speeds should easily be fast enough. Next thought would be to take the base station and cameras to another location and try there. Unfortunately success there doesn't determine if there's a problem with the connection to your router or interference in your neighborhood. Failure there would certainly be reason to get started on a support ticket heading for an RMA
dpoon
