Device offline
- 2
Best Buy will likely let you exchange the whole system. Your choice.
All 5 of my cameras were offline again today. The camera light was out on the basestation. Rebooted and they're back. It didn't record a thing for 6hrs. If I could I would return the whole thing. Im glad it works for some but there are a lot of people having issues after the updates. Go read the reviews for the app on the google store.
I started a thread a few weeks ago and here's a link, on how I troubleshot my system, in hopes that it would help some of the new users. Take a look as it might help. At least in my case it was all wifi related.
Woseyjales, are you saying you connected the basestation to the wifi extender through the ethernet port on the extender?
Not the person you were talking to but, yes, you connect the base to the extender's Ethernet port as if it were the router.
I tried that, I even ethernet cable from my router to my basestation. I'm going to see what I need to do about getting a new basestation.
livewire713 wrote:Woseyjales, are you saying you connected the basestation to the wifi extender through the ethernet port on the extender?
Yes sir.
Just got home and noticed all my cameras were showing online but not one recording for 5hrs. Hit the liveview button and this is what I get.
Rebooted my basestation through the web interface and everything is back online. Live view working again as you can see they all say just now. All cameras have a full signal except for the one on the back of my garage.
Gdot, can you reboot the basestation through your browser? Thats what I do with mine. It says its lost connection to the router or the internet but its just the cameras the basestation has lost contact with. Once I reboot my cameras come back online. If you go to settings at the top and click on the icon of your basestation there is a option to restart.
I think we all get this at some point for whatever reason. When I get it, the first thing I do is log out and back in. I just had to restart Chrome on my laptop to regain control (not for this specific issue - the library wasn't showing thumbnails and videos were "loading"). If/when this sort of thing happens, you should also try the app or a browser to see if it's one version that has an issue. And don't forget to check the LEDs on the base.
That is exactly when we started having trouble- about three weeks ago. It has to be an update problem because they were working fine for MONTHS and then Poof all the sudden!
While there may be an app issue, don't forget that you can use a mobile browser, too. You just need to tell the browser to use the desktop version through its menu.
- 2
