- 2
1. Setup Geofencing with custom modes for both Home and Away.
2. Select Geofencing mode.
3. Select Disarm mode.
4. Select Geofencing mode.
5. Select Back so that you can see what Mode Geofencing is using.
6. Result - from that point Geofencing will show Disarm as the Home Mode and not the Custom Mode.
To fix it
1. set your home and away mode to disarm and arm.
2 Save.
3. Set home and away mode to custom modes.
4. Save.
And here we are a year later and no response 😕
If you can't get an update on a defect after 8 months there is a problem with your support policy / process.
I recommend that you raise this with your management team. How can you be effective when you cannot get any support or communication from your support organisation ?
Please call me if you need help with the logic. It looks like you are really struggling to understand how this should work.
@ShayneS Any update ?
Still no update on this long standing product defect with Geofencing.
Arlo's programmers continue to confuse Arm/Disarm and Home/Away.
I just noticed this on my system a couple weeks ago. We've been unprotected for months between 12am and 8am every day because of a software issue. The issue I got was when I set to geo-fencing mode, and use schedule in home mode, the cameras stop funcitoning everynight at 12am. I captured screenshots, videos, and logs. I'm pursuing a class action lawsuit against Netgear and if any of you have documented proof that you would like to share, please reach out.
A lawsuit may be the only way to get them to look at a defect.
The support team are letting down what is a pretty good product.
This is a fundamental defect with a key feature and it has been open for 9 months. It should not be this difficult to get attention from Arlo support.
I have heard nothing from Arlo support.
This is a fundamental defect with a key feature and we are unable to get any attention from Arlo support at all.
It is this approach to support that drives bad reviews which will impact sales.
"Great idea but support is so poor that I would recommend you look at the alternatives"
Fix your defects. Listen to your customers. Or expect negative reviews that drive your customers towards the alternatives.
I will post a couple of negative reviews daily until I start to see some progress on this defect.
I will tell the story of this defect and the some of the key product gaps that remain unresolved for years.
Hi @XJW
The issue has been endorsed to our Engineering department, we will provide you with an update as soon as possible.
While I wait I will continue to post negative reviews on every site I can find. I have posted 10 reviews on 8 sites so far.
From my experience of Arlo support in the past few years I have zero confidence that the issue will be resolved quickly or at all. And communication will be very poor or non existent.
Your support team is in need of training and a review of support policies / priorities / funding. They are damaging the brand of a good product.
Engineering are confusing Arm/Disarm and Away/Home. The team should whiteboard the logic before they fix this one.
How can they make no progress in 9 months on a serious defect with a key advertised feature ?
There is something wrong with Arlo support / funding / priorities.
Or the support team is simply not very good and needs better management.
It appears that the technologists at Arlo have all the priority churning out new products rather than fixing the existing products. But without the goodwill of existing customers you will not as easily find new ones. I have been posting my observations on many sites and what I noticed was that there are already many many bad reviews. Fix the defects and the product gaps for your existing customers and those reviews will be positive. Coach your support teams on effective communication and your customers will become advocates. No response just makes customers very angry.
How likely will it be that this defect will remain unresolved for more than a year ?
Still no response from support.
@ShayneS I just posted another bad product review - poor support, no communication, glacial defect resolution........
It's not a good hobby but poor customer communication can make customers very unhappy.......
Arlo just don't appear to care at all......
@JamesC Can you get an update ? This defect has been open for many months with no update. The lack of any support or communication is appalling.
Config corrupted by the defect.
GEOFENCING is a key feature with an easily reproducible major defect.
And yet Arlo have not made any effort to fix it in 10 months.
Don't buy Arlo people.
Arlo ignore their customers, don't communicate, don't fix defects.
If Arlo get enough negative comments on tech and review sites then they may start to listen to their customers in this site.
Still no progress on this major defect ...........
Oh wait. Sorry this is the Arlo forum.
Support have provided absolutely no communication and after 10 months there has been no progress at all to isolate or fix this major defect.
The development team is working on an app release that addresses several geofencing issues being reported by users. We hope to have that app update available soon.
Approaching 12 months with no update beyond we are working on it maybe .........
- 2
