I just got a third camera (Arlo Pro), and I'm making sure I understand rules properly. (via the web interface)
The "custom" mode (currently called the default "All Motion On") is the only one that allows you to have multiple triggers? This is the only mode that I see that has the "Add Rule" button at the bottom.
If so, it all seems a bit counter-intuitive. I would think all the modes should allow you to add/configure the triggers as you see fit.
(Also, when entering the Custom Mode to view it, the only option is "Delete Mode", this is just bad GUI design. There should be a "Cancel" option)
You have to go to Modes, use at bottom ADD a Mode, name it whatever....
add your first camera A
set it to sense A, record A
set time and sense levels
review and SAVE
Now go back to the new Mode and EDIT for the second cam
add sense B, record B... Repeat time and sense
Now repeat as needed
sense A, Record C
sense B, record C
when done you should have 4 rules in the new mode...use it and check the running man in live view for black on cam A and B
ps... All MOTION ON is from the old SW...if you did updates that's why it's there...it's better to delete that old mode as it cause problems back then when left
hope this helps
You should now have the new default modes. Armed is in by default but I suggest adding your own custom mode so things are set to your liking and under your control.
Just to clarify, my Base station has the following Modes:
- Armed
- Disarmed
- Schedule
- GeoFencing (Only accessible via Mobile)
- All Motion On
Now I've only ever used "Armed" and "Disarmed" to control my prior 2 original Arlos. But these modes lack the "Add Rule" option anywhere visible that I can see. However, the "All Motion On" does have that option.
FYI:
HW VersionVMB3010r2
Firmware1.8.1.1_10234
So you have the "Add Rule" option on all your Modes?
ARMED does not have add a rule as by default any camera added is installed in it... no need to add more to it.
Also , its not a good idea to edit it as it is a way of allowing the system to work reguardless of what users do.
You are better off making a CUSTOM Mode by copying the default Armed and then you can edit it all you want.
TomMac,
In that case I must be doing it the wrong way.
I have 3 Cameras, and here's what I want to happen.
Any Motion by Camera A, I want to record on Camera A & Camera C
Any Motion on Camera B, I want to record on Camera B & Camera C
(As you can tell, Camera C only records when triggered by A or B)
So how would I do that by creating a custom mode, if it doesn't let me add rules? All it lets me do is setup one recorded action based on a trigger.
Once again, the only mode that allows me to have one trigger, create multiple cameras recording is the "All Motion On"
review and SAVE
sense A, Record C
sense B, record C
hope this helps
What the heck. It works as you described. Not sure what I was stumbling over yesterday. Maybe I wasn't attempting to save and then re-enter to edit to add additional rules. Based on my experience, I'm guessing the process could be a bit smoother..such as allowing the addition of additional rules without having to go out and back into it again.
Anyways..thanks for the step by step..that overcame whatever I was doing wrong.
Don't matter... you got it now.
