  • 4976 Views
Clangley5
Does anyone have safety concerns regarding cr123a batteries. Mine is outside under a metal roof overhang..
Thanks much.
The OEM batteries are very safe if that's what your asking....( cr123 )
The RCR123 rechargeable batteries can be an issue IF you use poor quality cells from unknown manf's.
A good li-ion 123 cell ( or 16340 ) will have a safety PCB built in to prevent over-discharge, over-charge.... without this there can be a possible fire issue.
Netgear only recommends the Tenergy li-ion cells built to their specs with thess safety features built in
seen here ; https://www.amazon.com/dp/B01N0DVFA7
steve_t
Master Master
No concerns but if you have Arlo Pro cameras, you don't use CR123A batteries
Clangley5
My apologies.
I have a Pro and a NON PRO.  So I still have the question.
