Just managed to wire up the wireless using an old 6v transformer than I had.
Wired up the shed yesterday.
Pop some wires though the battery springs.
Use a "chocolate box" to wire in parallel.
Connect to the transformer - hey presto, no more batteries 🙂
DW
PS: If you're smart you could connect in series and use a 12v transformer
https://www.youtube.com/watch?v=5T0utQ-XWGY
I already answered that - currently I've wired it in parallel with a 6v transformer.
But if you're smart you could wire it in series with a 12v transformer.
DW
It would be nice to have a jack plug rather than batteries.
Plus the cameras are excellent - it would be nice if they could double as a web cam.
DW
PS: wired up the shed yesterday, old 6v transformer, thread the wires through the
battery springs, parallel to the transformer. Could wire it in series and use 12v instead.
Just a note, cams don't run on 12v, they use two sets of 123 batteries in parallel ( 6.4 v as each 123 is 3.2 when new )
DW
