  • 6 Replies
  • 8541 Views
  • 6 Likes
  • 5 In Conversation
Breakaway9
I have 3 camera's. All 3 require a step ladder for access. All 3 are outdoors. All 3 always have 2 of 3 bars showing, when connected. All 3 disconnect constantly. I am so done with this.
6 REPLIES 6
chuck159
I have the Arlo Pro and it constantly disconnects which MAY be the reason the batteries discharge to 37% in just 3 weeks.
Constant disconnects are often due to poor connectivity between the base station and the camera. To isolate the issue, try bringing one camera (as a test) close to the base station and test to see if you still experience the same issue. You could also try elevating your base station to see if you still experience the same issues.
Breakaway9
See my original post, 2 out of 3 bars of connectivity, at all times.
mombotye
I've been having the same problem. Each time I go to check things out I get this on my screen. The only way I've found to get things going again is to power off then on. Then it does it all over again. I got these to keep an eye mainly when I'm gone. Is there no other way to restart it? Last night I read about scheduling it to turn off for 5 minutes every 4 hours. Zero recordings and offline again
Breakaway9
Zero support. ZERO.
ShayneS
Hi Breakaway9,
Have you tried contacting support through the website?
