Connecting to Verizon Jetpack
  • 4 Replies
  • 5300 Views
hoovedogus
I have a base model no. VMB 3000, currently running three cameras with a Uverse router. I'm moving to a remote rural area where all they can only provide  a Verizon Jetpack with 50Gb of data per mo. The jetpack has no ethernet connection, how can I connect my cameras? Will a Nighthawk wireless router work with my Arlo base station, and find the Verizon Jetpack signal?
You can get a simple wifi extender with an Ethernet port and plug the base into that.
The extender will hook into the jetpack
hoovedogus
I bought a Netgear Nighthawk AC1900 WiFi extender,, plugged the Arlo Base into it with an ethernet connection,, how do you connect to the Mifi7730-L Jetback? ,, It only has a USB outlet to it
Read the directions from the extender. The extender needs to connect via WiFi to your network. That way the base has a network connection to the Internet.
hoovedogus
Oh no!! Read the directions!! Lol !! Thanks for your help.
