How do I connect Arlo Cameras to Nighthawk R8300. Arlo came with base but range is not strong enough. Want to leverage nighthawk range.
Tried Sync camera by to Nighthawk by hitting the WPS button. Camera went through sync routine similiar to base. But says offline.
Too bad. I might be more inclined to buy more cameras if they had better range.
You don't.
There is no Netgear router currently supporting the Arlo / Arlo PRO cameras. They only talk tothe base units.
The only way to expand the coverage area is to add a second base ( or three ).
