@j_peace wrote:
Thanks for the quick response. Ok, so the bridge is basically just an overpriced rebranded repeater? My goal is to extend the connection of my base's WiFi since some cameras are a little far.
The bridge's job is to allow the security light (which uses bluetooth BLE, and not wifi) to connect into the Arlo system. So it's kind of a base station for the security light.
It can't be used to extend your base station range. The only way to do that is to purchase another base (and place it close enough to the cameras).
The bridge is connected to your home WiFi - not a base.
