Just bought a new Netgear Nighthawk X10 7200 router to get better wifi range in my house. I connected base station to ethernet port; and all my arlos are just working fine (connected via base wirelessly). I noticed that there are certain spots in my house where the base wifi range is not acceptable. I do know that my Nighthawk X10 has good range at every area in my house; and would prefer to have some of my arlos connectiving via my Nighthawk wifi (rather than base station).
Can I change the network name (SSID) for my arlos so that they (or some) are connecting to my Nighthawk wifi (instead of base)? I looked at my device settings for each arlo; and did not find a way to change the network name/SSID (not unless I missed something).
Please advise.
Won't work. The sync process requires not only the SSID but also the unknown passphrase/key.
Thx. So does this mean that in order for me to get decent coverage in spotty/remote areas of my house..that i may need to add another base or multiple bases ..then add/manage the arlos within decent or close range to the base(s) ? Luckily, I have my house wired with ethernet ports in almost every room. I really did not want to drop more $ on bases, and really preferred to leverage my nighthawk x10.
There's currently no router with the capability to be used as a base station. It requires at least additional firmware. Which routers may get this and when is an open question. Right now the only answer is a second base to get the coverage you need unless repositioning the existing base would help.
