Cannot log in to arlo website
  • 8 Replies
  • 6127 Views
  • 3 Likes
  • 5 In Conversation
Joe_Wi
I cannot login to the arlo site. This started a few days ago. I get the following error in my browsers:
"Secure Connection Failed
An error occurred during a connection to arlo.netgear.com. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP"
Anyone been able to fix this?
TIA
Use my.arlo.com.
arlo.netgear.com is left over from the period when Netgear owned Arlo.  That ended in 2018.
8 REPLIES 8
Use my.arlo.com.
greenweenie
The request still "times out" using arlo.com - tried 3 different browsers
dsfenton
Same problem.  Android phone app works but website doesn't.
greenweenie
Seems like it's been fixed - I can now login after 3 days
https://my.arlo.com/#/login
siren
I have tried my.arlo.com and keep getting "The request timed out."  no matter what web browser I use.
Is this during the 2 factor authentication?  Or are you not getting that far?
siren
I'm not getting that far.  I don't know if there has been an update server side recently because I USE to be able to login, request a code for 2FA.
FWIW, I can log in - just confirmed that using Chrome.
Did you try the usual step of clearing the browser cache?  And/or opening an incognito window, and see if you can log in from that?
