I cannot login to the arlo site. This started a few days ago. I get the following error in my browsers:
"Secure Connection Failed
An error occurred during a connection to arlo.netgear.com. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP"
Anyone been able to fix this?
TIA
Use my.arlo.com.
arlo.netgear.com is left over from the period when Netgear owned Arlo. That ended in 2018.
Use my.arlo.com.
The request still "times out" using arlo.com - tried 3 different browsers
Same problem. Android phone app works but website doesn't.
Seems like it's been fixed - I can now login after 3 days
https://my.arlo.com/#/login
I have tried my.arlo.com and keep getting "The request timed out." no matter what web browser I use.
Is this during the 2 factor authentication? Or are you not getting that far?
I'm not getting that far. I don't know if there has been an update server side recently because I USE to be able to login, request a code for 2FA.
FWIW, I can log in - just confirmed that using Chrome.
Did you try the usual step of clearing the browser cache? And/or opening an incognito window, and see if you can log in from that?
