Cannot find any Arlo Devices but can find Base Station. Help?
The seems to not be able to find any Arlo Devices but I can find the Base station Ive done everything including unplugging everything and starting over need help
Starting from left to right, what are the lights on the base station showing?
Have you tried to briefly press the sync button on the base then within two minutes briefly press the button on one of the cameras? You might have to wait for a minute or so for the sync process to stop. After pressing the button on the camera briefly, the LED inside the camera should slowly flash blue for a few seconds followed by rapid blue flashing. Wait for all the flashing to stop and the camera should be synced. Then repeat the process for each additional camera. It helps to have the camera close to the base the first time you sync them.
Brian
