Cant connect cameras
  • 1 Reply
  • 1383 Views
Kodak271995
Just bought made account connected base to wifi that worked when i try to connect camera to the base i follow directions hold sync button for 2 seconds until flashing green then press camera sync for 2 seconds until flashes slow blue then flashes fast blue and button on back of back turns amber color and no camera connected on app?
brh
@Kodak271995
Don't hold the button for two seconds as the instructions state. Just briefly press the sync button on the base then within two minutes briefly press the button on one of the cameras. You might have to wait for a minute or so for the sync process to stop. After pressing the button on the camera briefly, the LED inside the camera should slowly flash blue for a few seconds followed by rapid blue flashing. Wait for all the flashing to stop and the camera should be synced. Then repeat the process for each additional camera. It helps to have the camera close to the base the first time you sync them.
Brian
