Can you deactivate the siren feature entierly?
  • 1 Reply
  • 880 Views
Tnevil
I am in the process of moving into a new apartment complex part of their requirements are that you can not have a siren feature activated on the home security system. I am trying to see if the Arlo Home Security System has the ability to have the siren feature deactivated or not? I have not been able to find a direct answer and am hoping to find out before having to purchase the system. Thanks in advance!
The setting for using a siren is generally in your modes and rules. Remove that action (or disable it) for each sensor. Since this would be a new system, I believe the default is for the siren to be disabled.
