Can't set start/end time
Hi, I am using an android app. When I am in scheduling modes, I can't seem to change the start or end times. The time section is grayed out. Please help. Thanks
Ftm,
To schedule a mode to a day that has no existing modes scheduled. Click the green + icon in the top right hand corner of the app. Once you click that a menu will open. You can then elect the mode you want to set and the times you want that mode to be active and click Add. Once that mode is added to the schedule you can edit it by clicking it on the schedule screen. See below:
Hope this helps!
