I can't seem to set this in Armed's camera's rule when I uncheck "Motion is detected". I know I can use "1" motion sensitivity, but I prefer to be 0 (off). Is this a bug?
Also, is there a way to set a time limit? Like temporarily off for a hour.
Thank you for reading and hopefully answering. 🙂
Normally you'd do this by removing the rule for that camera - which disarms it when you activate that mode.
I suggest creating a custom mode for that, and not use Armed.
