I was able to link my base back to the Arlo app, but not able to link cameras back. I tried the factory reset, hold sync button for 15 seconds and wait for amber light to blink 3 times but it never does and the cameras will blink rapidly blue the appear to sync with the bas station but I can’t see them on my app.
The older cameras (older than the Ultras, including the Pro 2 you have) can't be reset by the sync button. The only "reset" is to pull the battery out and reinsert so the camera returns to a known state.
As for syncing, make sure your remove the cameras from Settings, My Devices before trying to sync them again.
These cameras don't actually need to use the app to connect them to the base. Briefly press the base sync button - don't hold it - and then a camera sync button. What do you see as you do this process?
1  -
1  -
1  -
