Upgraded iPhone from 7 to 11 pro and can’t log into the app, says it can’t recognise my device. When I try all verification methods no luck.
Have tried reloading app, restarting phone etc
Hi Khume,
Is this happening when you're on cellular data and/or WiFi? Could you provide a screenshot that shows an error?
Message 2 of 5
9,648
We have same issue with Arlo Pro2 not recognizing iPhone 11 all of sudden
Message 3 of 5
9,515
See attached screen shot
Message 4 of 5
9,512
Try disabling 2-factor authentication from https://my.arlo.com.
Set it up again after your you get the app working on your new iphone.
If you also can't log in at https://my.arlo.com you'll need to contact support: https://www.arlo.com/en-us/support/contact.aspx
Message 5 of 5
9,499
