  • 5 Replies
  • 2619 Views
Aussymatt
Hi i travel Alot and have never had any issues viewing arlo from 15 different countries. The problem seems to be i can log in but all it says is getting status and does not go any further. Ive logged in via wifi and also through the local vodaphone micro sim card. Internet ect works fine and fast its just arlo that i have issues with. Not sure if i need to turn location on phone etc. Running a galaxy s7. Tried logging in also to a iphone 7 same issue.
5 REPLIES 5
JessicaP
Hey @Aussymatt,
Are you using the app to login to Arlo or are you using the web through your phone?
Aussymatt
On both phones i tried using the app. Havent tried through the web thanks
Aussymatt
Ok so looks as though app has been updated. I can see base station states that its armed yet all cameras now display status as offline. Obviously i cant reset each camera manually as im overseas. Any ideas?
Aussymatt
JessicaP
You cannot restart your cameras remotely as you need to be in the same WiFi network as your camera. But you can restart your Base Station through the "Device Settings" on the Arlo app.
