I noticed about an hour ago, my app says my system is offline. I have a solid green internet light, but a solid amber camera light. I've reset the base twice, removed one of the cameras and tried to add the camera back..... nothing has worked. Very frustrated with this at the moment. Hope someone can shed a little light on a fix.
Thanks.
Nighthawk11,
A solid amber camera light indicates the base station needs to be claimed. When you say you've reset the base station, did you factory reset? If so, you will need to add the base station back to your account before syncing any cameras.
Nighthawk11,
