  • 1841 Views
Magpyz1
I can log in to type this into the community, but as soon as I go to My Arlo, it first tells me I need upated Flash (no, I don't, it's updated), then it tells me my password is incorrect, then it tells me it's timed out.  I need to reset the Schedule on my cameras (it's notworking on the phone and other forums show you have to do it on the computer).  Hard to when you can't log in!!!
@Magpyz1 wrote:
I can log in to type this into the community, but as soon as I go to My Arlo, it first tells me I need upated Flash (no, I don't, it's updated) ...
The flash issue is definitely annoying.  You should be able to allow it to run (overriding the browser settings) but the method depends on what browser you are using.
On the password issue - check the browser's saved password list,  and delete it for my arlo if it it is present.
cmilligan
How do you do this for IE and Firefox?
I posted something for Chrome, Firefox, and Edge earlier here: https://community.arlo.com/t5/Arlo-Pro/Adobe-Flash-Player-Update-Failure/m-p/1722871#M61486
Though the FireFox bit came other users, as I don't run flash on my PC.  I haven't tried IE (won't use it if there's another option).
