Can't connect to the internet
I set up the system last night. It worked fine but today it says that it is not connected to the internet. If I move one of the camaras it sends me video however I can't see live video? What gives.
There are various things that can cause this. Typically, when I have some sort of display issue, I log out and back in and the problem will clear itself. Can't explain why this helps, just that it does. If that's of no help, try power-cycling the base station. You shouldn't need to do this on a regular basis - if you do, something is wrong.
Also, try both the app and a browser. If the browser has an issue, try a different one. Sometimes clearing the browser cache helps, too.
ShaQ,
After the suggestions made above are you still having issues? Please let us know!
