I have read all of the comments and tried all of the tips to no avail. Still getting amber flashing on camera - no connect. Tried rebooting base station and starting sync process over & still the blue to amber flash of death. The only issue I can tell is that I have to hold the base station sync button down for 8 seconds to get the green flash on it. May just have to return the unit and settle on just one camera.
Azony wrote:The only issue I can tell is that I have to hold the base station sync button down for 8 seconds to get the green flash on it.
No.... By holding down the base sync button, your putting the base into a usb mode ( which isn't used BTW ) and the cameras will never sync.
It only takes a QUICK push on the base sync button ( do not hold ), then wait about 3+ seconds and push the button on the camera.
Azony,
Were you able to successfully sync your cameras after a quick press and release as described above?
Please let us know,
I realized that I was unable to connect because I was holding down the sync button too long. Thanks JamesC for responding.
I really like these cameras. I am now up to 3 cameras.
Azony
